crashed
riteo i had a crash my fault was changeing a cd.... thank god it was a polo I'm driving, god it a strong wee car :)
problem and damaged that happened is that front bumper poped out bonnet slight dent no problems there however the seatbelts are jammed WHY??
done some research an think it something called seat belt pre-tensioners, dose anybody no how to fix this????
o p.s if any cares I'm all good apart from sore ribs were i cracked a week ago, no animals were hurt haha...
  • Replies 14
  • Views 1.8k
Yeah, your pretensioners have gone off. They pull the belt tight in event of an accident.
You'll have to get a new set of belts.
buck sake do u know how much for right and left side??? would normal seat belts from another polo with out these pretention things on it to fit the car???
Probably £10 to £20 from a scrapper.
do u know if normal seat belts would fit?
Those would be the "normal" seatbelts for your car
In most modern (2000+, but i know of some pre 2000 cars that had them) car the seatbelts and seats are wired into the airbag system, and one "talks" to the other so getting a set out of something else may make the dash warning lights come on, or deploy the air bags prematurely or not at all when you might need them.
Would be safer if more expensive to do the job properly and fit the right ones tbh.
riteo went to vw today £400 for the to belts and for them to fit it I'm still not sure what to do,,
I've just noticed the bar under the bumper is bent and a few clips in the bumper and grill are broke so looks like its gona be costly for changeing....
wonder how much the merc will be to fix haha thats the car i crashed into it was a clk or cls modle.......
INSURANCE ????????????? O CANT WAIT TO SEE MY RENEWAL HAHAHa
thanks for all your help
i went t the local scrappy for a new seatbelt for my mams car a few weeks back, payed a tenner and took me about half an hour to fit it, get yourself to the scrappy!
rito folks thanks for the help once again... went to the scrap yard however there were none so hada buy them of vw £135 each and now I'm geting the fella thats doing my body work to fit them,
so roll on wednesday d get the car in an fixed....
Make sure he does the wiring properly. Seatbelt pretensioner wiring is quite a common problem on a few cars causing the airbag light to stay on, my Saxo did it a lot after fiddling with the seats.
you will need the fault codes erasing if you are fitting new belts
if not it could mean the airbags/pretensioners will not activate in the event of another crash.
in some cases the airbag ecu needs replacing if a sufficeint crash has occured.
do u know were i can get these codes???
i left the car in yestarday to my body mec.... to see what damage was done :( BAD NEWS... :(
might need a new front panel as all the top and headlight clips ate broke, hes gona strip it today and see what the full cost will be... i know the guy so I'm not bothered about being riped off.
he said that he will also fit the seat belts however he aint got a computer to fit them?
will he need one?
he said that he just needs to disconnect the battery and fit them in and connect the battery up again... is it that simple?
i also know a guy wit the computer will he be able to just reset the codes and thats it??
I'm asking your opion now vw are saying its going to take 4hours to change the seat belts MY ARSE IT IS and its £60 an hour HAHA
what you guys think..........
thanks
o p.s i had to buy the belts of vw, couldnt get them no were, now to price a full front pannel..
Same on my saxo, It was always the plug under the passenger seat, every time someone moved it to get in the back the light would start flashing..
could it not just be knocked off with the computer? and sorta over written not to come back on again???
That's what everyone means by re-setting the fault codes.
