Hi all
Hi all. I am new to this forum today.
What i really need is some help with the polo i have just bought.
Its apparently well know on the seen. Its a mk4 1997 1.4 16v in black.
Right picked it up yesterday. On the way home got stuck in traffic behind a traction engine, for about 8miles and because it was going so slow, my temperature gauge hit the roof, and steem came out of my bonnet. So i pull over to let it call down and notice that the expansion cap on the tank was not tight.
So with most of the coolant gone i manged to get it home, and today took the rest of the old coolant out of the expansion tank and it was horrid brown stuff, so not good.
Next i washed it out and then put new coolant in, seemed fine and temperate was not going up, so went for a drive then got to a road where lots of speed bumps are and i had to really slow, and the temperate gauge did it again.
so i pulled over and let it call down and then looked at the expansion tank and it had gone down a bit and so filled it up to max again, and it seemed fine on the way home.
So it happens when get slow speed for a long time, and also the extra cooling fan does not cut in.
Right more problems are.
It idles by itself e.g it stays at 800rmp and goes up and hits a 1000 then goes back down and stalls.
Is this timing out or something. the guy i bought if of said it had been serviced but i dont think it has, unless really badly.
Please any help would be great. thanks
  • Replies 13
  • Views 1.6k
Hi mate same thing happens to me shortly after buying my 16v last year it turned out to be the theromal stat and houseing . One garage told me I had an air leek in the head gasket which was a load of shit and found out it was the ts and got it sorted . And the idel problem I had that aswell but seemed to on and of. I never have found out the reason for that but have heard it could be the idel valve. Mine fixed it's self and stoped reving freely after I cleaned out the throttle body/ inlet then oil on the thorttle cable . This sorted that out but randomly still did it, put a new starter motor , spark plugs some time after and has completly gone lol (not sayen a new starter motor and plugs will sort it) . The idel problem seems to be quite common get some carb cleaner and this should sort it
peace
peace
Hi there.
Thanks ever so much, yes i thought it may be the thermal stat, because it may be getting stuck, how much is this to replace.
So the radiator fan may be ok but i don think it is, it should work as well shouldn't it.
Arrr ok i so hope its the not the idle valve, are they expensive. Cool yer i am going to do that then when my boss gets back from holiday, i am a training motor mechanic, so hopefully this will get sorted.
Well i am probs going to do a service on it anyway because i dont think it has had one, even though the owner said it had. 8-)
I have paid a lot for the car, and then it does this to me arrrr, also today had so much trouble getting new tyres for it, 195/45/r14 but order 195/45/r14 i only wanted one but they are differnt so had to have two.
thanks again. :-)
one sec you say all thick brown stuff was in your collant bottle?
yer well not thick but brown stuff.
Edited by dc bmxer
Your a trainee mechanic? Then you should probably know its THERMOSTAT. Whats a thermal stat?
mate the thermostat cost like 8.50 for the part an a tenner for the houseing. cost me £100 in all fitted but if u do it your self then it wont be much
have you just bought it? and you paid over the odds (maybe a little) for it? and it over heated on the way home?
I would be thinking about getting your money back mate.
Loads of valvers for sale, no need to buy a lemon.
Edited by ben_reza
Well yer ok, i should know but i was unsure theirs lots that can be the problem, Arr here we go i cant spell that well ok, :?.
O ok then not to bad then, its just some cost a lot on some cars, cool its all ok then. thanks. :-)
you might not even need to bother with the housing....
i had the thermostat punch a little hole in the 'spider' that mounts it.
its a bit difficult to explain withour a picc, i looks like 'Y' and the
i took a trip to a local shop called fit-a-part who supplied me with a new thermostat with a fatter actuating bar that fitted over the old hole.
In the que for training to be a trainee,by the sound of it. Learning one's ABC usually comes first,though..
Its clear there's rust in the coolant so yeah you do a flush and re-fill. Obviously this will include bleeding air locks.
Its overheating fast and the radiator fan isn't kicking in so its totally expected for both the radiator pipes to be cool,indicating a sticking thermostat - resulting in the overheating.
New coolant and thermostat.
Absolute basics in mechanics.
Arrr cool thats sounds good, ok well as soon as my boss is back i will be up work, taking it apart.
Cheers for the help.
Well today my car got even worse. On the way back from finding a place that puts the sort of tyres on my wide wheels, which took ages.
My car when i came to a stop it died on me, then i started it again and managed to get it home, then when slowing to a stop to put it my drive way it stopped again, and would not get going again.
Then the battery warning light came on, don't know why its a new battery according to the owner i just bought it off.
So its starts then dies anyone any clue why this happens, either timing out, alternator not charging the battery ect.
I think ever since it over heated something has blown or made something in the engine not work.
Any ideas
