Mk1 Golf seats into Mk1 Derby
Hi guys,
does anyone know if Mk1 golf seats will fit into a mk1 derby??
If not is there anyway i can modify mk2 golf seats to fit into a mk1 derby?
thanks!
  • Replies 9
  • Views 2.4k
My mk1 golf seats have the release lever on 'outside' as opposed to adjacent to the tunnel on mk2 golf seats. So mk2 golf seats will normally not fit without modification.
I'm not sure if the mk1 polo seats have the release on the outside, but going by the mk1 golf they should be.
I see....i will have to try and source some mk1 polo seats...proving to be quite difficult at the moment.
Thanks for the help
What difference does the side the levers on make?
I'm 99% they will fit mate
i think mk1 polo seats will have a release on the outside, as my early mk2 does although the seats seem quite easy to convert
euro-derby had a set of mk3 gt seats converted for cars with release on the outside
so to answer your question the mk1 golf seats should fit into a mk1 derby
The release lever will surely attatch to the bracket in the middle on the release mechanism wont it, so it shouldn't matter either way. You'll just have to learn to use your other hand!
it does matter mate, seriously if you dont know, stop spitting out information.
the release lever on the other side does make a difference, as the release lever pulls a pin that returns back into the slider with a spring. Its when you pull the release lever, that the pin slides out and allows the seat to move back and forward.
with the release lever on the wrong side, itll never engage the pin obviously and therefore you cant move your seat back and forth without leaning down pullin the pin by hand shifting forwards or back and then pushing it back in. its very fiddly trust me.
mk1 golf seats will fit in mk1 polos, the release lever is on the correct side. mk2-3 polos and mk2 golfs onwards have the release lever on the different side so can still be fitted but youve had that problem
it may also seem like a feasible solution to use the drivers as a passenger seat, and vice versa, but this means the threading for the seat belt buckle is on the wrong side, so for a driver it would be nearest the door.
having said that, it is very easy to swap the release levers from one seat to the other, so its possible to use corrado seats (or the like) which sit very low in a polo and still retain the sliding feature
Thanks for all the help guys!
Managed to convince my mate who i bought the car off for a tenner to give me tho original seats he was planning on using!!
HAPPY DAYS
Both my posts were more like questions. I wasn't 'spitting' information thank you.
But as i said, dont both styles of seats have the release mech meet in the middle? As long as the release brackets on the car fitted the release levers, then they should work shouldn't they?
This is what i thought,but when i sat the runners in it didnt seem to slide..the middle bit went in fine just wouldnt slide forward....
The originals are going in today so its all good
