Number Plates
Hi,
Been lurking around the forum for awhile now and just bought a GTI 6n2 :-D
Anyway, what are the rules regarding letter spacing on number plates?
I'm about to buy a private plate but would want it spacing like
xxxx xx
Would this be possible?
  • Replies 9
  • Views 1.8k
Pretty sure that with 6 letter number plates it has to be 3 either side so therefore you'd need it illegally spaced for that.
www.dvla.gov.uk/media/pdf/leaflets/v796.pdf
Anything to distort it's original reading I would suggest is illegal.
Plus be guided by the producer of the plates, they will probably get you to sign a disclaimer
the only thing I've seen people get away with is taking out the space in shorter number plates
for example:
S1 AMO
to S1AMO
for example:
S1 AMO
to S1AMO
That's still illegal - the space between the 1 and the A must be at least twice that of the space between the 1 and the S.
I know this because i run a five digit plate myself,and it incorrectly spells one complete word (it's a bit more obvious than S1 AMO, more like S1 AMD so it'd be unnecessary to have it as S1AMD anyway).
I dont mind though,i think its a bit desperate to change the spacing in order to make it more obvious. You can either see it or you cant,no skin off my nose,but i suppose it being only five digits makes it blatantly obvious anyway.
While on this topic, what are your views on metal stamped plates?
My 2p - i prefer them,they're tougher. Legal GB ones are available,so i dont see why not.
I want the metal ones with plastic letters though - not as tough,but proper retro for the old skool motor.
number plates.....
Basically, the easy way to remember what is legal is this- go to a garage, and look at a new car for sale. The plates on that are legal. It will probably have a plastic reflective plate that looks like every other plate in the UK.
Yes, it is nice to be a little different, but you dont go putting square wheels on your car, so dont go putting 'different' plates on either.
Moved to paperwork.... with all the other posts asking the same thing.... and this FAQ..... Thread closed.
