wing mirrors
would the stated wing mirrors above fit on a 9n. like the idea of having the indicators on the wing mirror. also is it possible to wire them up easily. maybe connecting the wires to the relay or near it anyway??
cheers
sam
  • Views 787
In theory you should be able to extend the mirror wires thru the door plug conduit and then somehow into the wing behind the dash and connect to the original side Market wires! If they don't fit I think I've seen aftermarket ones? I may be wrong! Or maybe use you baseplates add the 9n3 ones to them and bang! Job done LOL
yea sounds positive tbh. i was planning to smooth the side indicators over. just to make it easier do u know how to take the wing off?? it shouldd be easy to do but just any info would be good.
sam
Not on a 9n but on a 6n you just take off the triangle trim and unscrew 3 screws!
