Leaking!
Ok got in the car friday morning and the passenger foot well was damp, but behind the seat there was 2 inches of water!! Because of the angle it was parked at.
so scooped all the water out but the carpets are still wet need underneath is soggy.
it fucking stinks like a cabbage!!
I'm not 100% sure where the water is coming from, i have read a few posts about this and its got to be the door seals which look fine to me, or the windscreen.
I am going to take the seats out today and dry out what I can, also stick a hose on the top and sit in it to find out where the water is leaking in from.
now I want to pull all the carpets up and get rid of the water, is there a way to do this without taking the centre consol out?
Any help will be much appreciated
  • Replies 12
  • Views 1.4k
is it a mk4 pal?? if it is the center console has to come out to get carpet up, or you can just cut round it..............................................
have you cleaned the pollen filter? the center console comes out easy, its just 1 screw at the front and two plastic bolts under the gear gaiter. : ) but if you put charcoal or coffee beans in the car then it will get rid of the smell aslong as you give it a clean aswell.
yup yup its a mk4 , took the skuttle panel apart and cleaned it all out, I think it may have somthink to do with the dranage holes but I have cleaned it all up now.
Can't see no problems with the windscreen but then I wouldn't know much about it anyway.
Bummer.
You don't have to take out the center console to remove the carpets. just remove the seats and trim, should only take 30 minutes.
is this a common problem on mk4's then, and what is the most common place for it to leak from???
ok everythink is stripped out.
I HAD THIS PROBLEM IN MY POLO ! i found it was the plastic/ rubber thing above the pollen filter ... i took it out to see it wasent in properly and has changed shape. i heated it up on the cooker pushed it back in to place put it back in properly now i haven't ever had the problem again! sweet :) hope this helps x
nice one thx, yeah i cleaned all round there and it hasent happened since, still don't want to put the carpets bk in because knowing my luck it will happen again.
Could it have been the heater matrix?
had this with my dads rover 75. the carpet has like 3 inches of sound deadening on it. it weighed a tonne and took about a week to dry out. found the leak tho, it was the front scuttle had a blocked water runaway.
pain of a job but with a leak there is always a way to fix it, so better than some mechanical problems i think!
I stripped the car, and then closed all the doors and ran a hose over it, looking inside to see where the water started to run in from.
I have this problem at the moment. I paid nearly £150 to have my windsceen replaced twice (Thats what i was told by a proffesional was the problem)
only to find that its still leaking! the leak is only in the passenger side though.
Is this where it normally happens in a 6n?
take the plastic off from near the windscreen from under the bonnet were the pollen filter is and give it a good clean its probably full of crap mate, thats what makes it leak happend to me
