16v speedo problem
my speedos not working in my car, the revs work and sometimes the speedo flicks up to 20mph and down to 0mph, if i put the clutch down and start breaking it goes up to the speed (i think I'm doing) and starts going down also the milage wont go up but sometimes it will
can someone help me please.
thanks Yasser
  • Views 1.5k
speed sensor on the gearbox i think , mine did this after changing the gearbox :)
were abouts is the sensor on the gearbox mate? do i need to change it or what? and also is it a hard job to do or quite easy?
thanks Yasser
Mine's doing similar and i've just ordered a new set of clocks, as thats what i was told could cause the problem.
hopefully that'll be it as it'll be a nightmare to change the speed sensor on my car :(
i heard that changing the clocks may sort the problem, let me know if changing the clocks sorts the problem out mate
thanks Yasser
clocks fitted and so far so good :)
hope this has helped.
thanks mate will give it a go see if it helps me out
