"HELP" Weak/Intermittent Spark "HELP"
"Weak/Intermittent Spark"
What can cause a Weak/Intermittent Spark??????
Cheers.
  • Replies 10
  • Views 1.5k
Knackered plugs/HT leads?
Just had that all changed.
Thanks vo.
possibly a faulty coil if you have changed the above parts
yer changed the coil need had full servise but still nothing could it be ECU?
have you tried having a diagnostic check run to see if it throws up any errors?
ECU Wont plu in to any computer, not even vw mate.ha Joke ay
Nothings come up on the ecu.
what year is it? and what engine?
Edited by Mister D
1998 R reg
1.4 8V
Cheers.
1998 R reg
1.4 8V
Cheers.
May be 1997 to be fair, the ECU has gone once be for?
