AirRide - Front Struts & Bags
Very good quality front kit - Rayvern
2x Front struts & 2x Air bags (AVO Shocks, Firestone Bags)
All required fittings included
£670 just for this front setup from Rayvern!!
Fitment:
Polo 6N + other polo models
Easily modded to fit mk1/mk2 golf and others if needed...
Mk1 mod - Upgrade to mk2 stubs for the correct bolt hole spacing on the bottom strut mount (Gaining better brakes and more wheel clearance (offset wise) as well from larger pads and shallower calipers). There is an aluminium spacer ring which would need very minor machining in order to get it to spin on the bearing built into your mk1 top mount - Job Done! ;)
Even less fabrication would be required to get this to fit onto other vehicles (mk2 etc.) but the mk1 mod really is a walk in the park!
They've had very little use, 2 minor marks on the bags which can be easily repaired if you're worried about them at very little cost (DIY job).
£350 ono
  • Replies 12
  • Views 679
Just to check, this is to raise and lower front end of the car?
If so, I really need these...
yep thats the one mate ;)
All PM's replied!! :)
Bump! ONO
pic update:
just to help out mate
I've now had 2 cars with rayverns air ride and i swear by it and the price you've put the kit up for its a bloody steel
bumps
thanks dude, not trying to rip anyone off, i know i could price it higher but thats not what I'm in it for! ;)
How much do they lower and raise by?
120mm full height to full drop :)
What other bits are needed for the set up on a 6n polo exactly?
tank, compressor, solenoids, switches/ gauges and air line (you can get all that for about £200)
the most expensive part of air ride systems are the bags and struts and what i have priced them at will make this a very cheap kit to get you set up! ;)
installation is a piece of p**s too
eBay
