polo 1986 coupe s
I've been trying to get the wife's mk2 coupe s to idle for a very long time, its been off the road for months. I've recently started to try and fix it again but it feels like I'm hitting my head against a brick wall! Everything works great on the car but it just won't idle, I've put it down to the carb. So anyway to cut a very long story short has anyone got a pierburg 2e3 in working order please? I have tryed to post in the wanted section but I can't for some reason :/ Please help I feel like torching it!
  • Replies 13
  • Views 1.8k
Throw me a bone here! It is the wife's car but I love to drive it also when it goes! I want it to go so I can have some fun driving on the road...I'm stuck with a BMW 518 e34, you must feel sorry for me now!
Try posting this in the Engine section under the title "Pierberg Carb Mk2 CoupeS Wont Idle"
Or ask for the thread to be moved :)
The pierburg carb is an area that I've always never understood, if I hadn't switched to a weber I'm sure I would have got to the bottom of what I'm sure were similar issues. This thread might shed some light...
http://www.clubpolo.co.uk/forum/index.php?...amp;hl=pierburg
This might also help but I think is more concerned with another pierberg but I reckon they all tend to have similar problems which are fixable. Your talking about a car that is over 20 years old that needs some investigating and TLC.
http://www.clubgti.co.uk/forum/showthread.php?t=124945
gave up on mine and bought a weber...fairly dear but it runs like a top now
When you say it wont idle, do you mean it revs, or just dies?
What have you checked?
Have you checked for air leeks between carb and manifold? Fairly common fault
all these 2e`s that everyone`s chucking i`ll have and make work again please :smirk:
its normally just a pull down valve or the idle jet , tho sometimes they just want a soak in a bucket of thinners for a week
brilliant carbs when working
it's usually down to the wax-stat which operates the auto-choke as far as I'm aware.
the polo carb has no wax stat , that is only on the bigger 1.5 to 1.8 golf`s
The autochoke works off a bi-metallic strip which responds to the heat of the coolant flowing through the unit, it also has memory too.
They are great carbs when they are working, but as said the adjustment of the carb can become troublesome since the metal strip loses some sensitivity as well as the fine gauge springs that tension the auto choke unit. This coupled with a faulty pull down unit or cracked gasket will lead to problems that seem incurable.
Just takes a lot of patience and a thorough rebuild, which admittedly is too much for some in both time and expense
Yeah,the auto choke works by the expansion/contraction of a spring (like the fuel gauge) which is operated by the coolant water temperature. When the coolant's cold,the choke's on - when the water warms up,the spring opens and turns the choke.
The point in which it does this must be set in just the right position in order for the choke to operate properly,which is why its degree-adjustable like the distributor.
What happened at first was when driving the car would occassionaly stall.. it was not until I fitted a side exit exhaust for a bit of fun the small problem turned into a bigger! It was fine for a couple of weeks...I put it down to increased flow by way of the straight through exhaust making a small gremlin bigger but I'm no mechanic!
At the mo I can get her started quite easily by holding my foot down and turning her over, but only after I removed the inlet and the carb, and re-sealing everthing. I've had the carb apart 5 times and cleaned all the jets with a airline and re-sealed it. Starting only got better when I took the manifold off and the rubber mount from the carb and fitted it all back with copper sealent. One thing I have not done is check the rubber seal at the bottom of the inlet, heater thing.
She will run on choke but when it cuts out the motor dies, she will run also if I hold my finger over the idle valve and she will rev clean then also with no pops and bangs, my mechanic just tells me to get another carb...which I want to try so has anyone got one? I can pay via paypal or you can list via ebay...
Well holding my finger over the top of the idle jet makes the car run OK, does it just need a new idle jet or am I restricting air from somwhere else on the carb?? Have you a idle jet I can try?
out of curisoity turn you are idel screw anti clockwise 5 turns. run the ar an ddo what u usually do for an hour ( inluding scream and shout ) then turn it clockwise 10 turns. Do what u usually do for another hour. If u find a progressive diffirence start turning you are idle screw back 1 turn at a time. MAKE SURE YOUR CAR IS WARM WHEN U DO THIS or the choke will completely offset what you are trying to achieve. There is a point to this guys thru experience so dont jump on the band wagon saying oh this will only slow down, speed up blah blah blah etc etc etc. Just do this bud and then see if any change when u turn idle control screw bak. remember each time how many turns u done each way from the start.
