Got a door for my white golf but it's black:(
Got a spare later type door for my white mk2 golf gti, but it's black so I'm going to attempt to spray it probably with spray cans. Some guy told me that all vw's have a white undercoat anyway. Will small dings and scratches just instantly uncover the black? Obviously 2 pack would be the way forward but I don't have a big enough compressor and don't want to have to learn a whole bunch of new techniques.
I think I'm going to follow this method of spraying which makes sense to me, put it this way I've made enough mistakes to know how not to do it..
http://www.gramheavy.org.uk/junk/images/Ra...Spray_Guide.pdf
Cheers.
  • Replies 9
  • Views 971
personally I would of done a gray primer, just so you can see where you have sprayed more or less across the bonnet.
Using the gray you will clearly see where you need more paint and where you don't.
shame you dont live closer, my mate has two white doors for his black mk2! couldve swopped!!!
^ This is typical, where I stay it isn't worth holding out to get the right colour, rarely come across any early vw's let alone specific colours.
Thanks for the advice on the gray primer, that certainly makes sense to me. Going to get the arch trims off this car and pray theres no more welding to be done which will mean more painting.
give it a good sand with 800 wet paper with some soap in the water
and id use white primer , will make the paint cover easier
^ see I'm seeing logic in this also because the primer is matt anyway and you can see the gloss going on. I'll see what the paint shop guys think?
800 grit with some car shampoo in it i reckon. I've never seen the logic in using fairy liquid which I read on other forums surely with it being full of salt like most household products your just massaging salt into the panel?
Anyone else shed light on what shade vw used for primer? I'm sure it depends on the final top coat.
i worked at a paintshop for 16yrs mate...if you need talking through it just ask..
nothing bad will happen if you use grey or orange primer...it will just take alot more coats to get the paint covered...if the black is sound you could paint directly over the 800 sanding marks if you wanted
dont use car shampoo as it often has wax and gloss aids in it , fairy is ideal...for this job you want to strip any grease and silicones from it ....just dont use fairy to wash the car weekly
so...
wet sand 800..until all shine has gone , no need to sand to bare metal
white (or whatever) primer until its evenly covered , 10 mins between each coat
mist a coat of matt black on..this is called guide coat
sand again 800 or 1000 until the guide coat is gone ,
lay the door flat and paint on the white ...10 mins between coats should do it , you can 1200 between coats to keep it smooth if you wish but leave it overnight before sanding
Cheers for this, yes I've seen people on the box (programs like overhauling) using a guide coat which I will go for.
Now here's a question, I had welded some holes on my tailgate and ground them down to what I thought were flush then a bit of filler, then u-pol etch primer, then tetrosil high build primer, then a colour match rattle can. when rubbing down between coats I stupidly exposed metal (didn't grind shy enough) and went to apply etch primer again and just got this reaction where the paint cracked. I remember trying to rub it back and only using the high build primer ( I was getting impatient by this point) but to this day the final colour coat has this cracked look to it which will need re-done. I take it you can't put etch in any way over other paints?
Just one other question,These colour match cans are acrylic right?
So they must have a clear coat to protect them right?
you should be able to etch over other stuff...although its only needed on bare steel
sounds like too much too soon ., or incompatible products , always let it dry out well if theres a reaction
dunno what cans you are on about...I've used halfords ones and they're straight gloss , no clearcoat (as the car should be too )
Yes I reckon I had lost patience before, too quick with different products, all part of he learning experience.
As far as the rattle cans go I'm confused, these were mixed up to match my polo's obscure red LA3E colour, it's just I thought that with being acrylic based they need more protection as with the new water based paint systems that the pro's use. I thought that it was the old cellulose paints that were a one finish paint. I didn't use clear coat before it's just I've not been happy with the results I've had. Again I think it's all about taking the right steps and letting coats dry. It was also in the colder months now i think about it. I suppose it takes one minor error to ruin the final finish.
Appreciate your professional input. Just got to try and get near the golf now, starting to find the breadvan a bit small. Gave my dad and brother a lift the other day and it was pure comedy with three of us being around 6' tall. Been on club GTI forum a lot getting a load of good info on the 8v digifant.
