G40 Cup Car Gearbox with L.S.D
For sale an original cup car gearbox with Gemini Diff.
The box was rebuilt about 2-3k ago (unfortuantely i dont have a receipt for this). It has however just come back from a strip down an check by JP Race in Silverstone (which i do have a receipt for). They confirmed everything is fine inside and no rebuild was necessary, although one seal was replaced as it was damaged during removal. During the check I had a speedo take off gear installed/replaced as the race boxes didnt have or need these.
The price is £850
and would ideally be collection from Silverstone Northamptonshire
Matt
Edited by KustomPolo
  • Replies 20
  • Views 2.1k
BTTT
Bump, I can take to ED38 tomorrow (Saturday)
BUMP
what are the ratios in this?
As far as I'm aware they are the stock ATV ratios.
Hi would this gear box fit a 99 mk4 16v polo engine code afh?
Cheers phil
You'll need to swap the driverside drive flange and seal carrier. Easy to do. You also need to check whether your's is cable change as the casing may be different.
These are the bits you'll need to swap over from a 6n gearbox.
But bear in mind doing this may weaken the gearbox:
http://www.clubpolo.co.uk/forum/index.php?showtopic=163349
http://www.clubpolo.co.uk/forum/index.php?...t&p=1427874
you wont be able to swap the driveshaft flanges as the gemini diff uses special ones to suit it. They are thicker and have spring clips on the ends to hold them in as there is no way of putting a bolt through the middle of the gemini diff (assuming it's a phase one like mine).
BTTT
Hi... Sorry, dont wanna seem ignorant but - whats the advantage of this cupcar box exactly? If the ratios are the same? Stronger?
BTTT
BUMP
  • 3 months later...
Now on eBay
the ratios are the same as the atv box as stated in previous posts on this topic
the box is a verystrong box and the gemini diff is a lot stornger than std diff it may be a limited slip diff
Just over an hour to go
Well it didnt sell on eBay with is a surprise as i thought that was a bargain price, i guess its time for the market to decide so offers via PM please.
Weekend Bump
could i fix this onto a 1.6 16v block from a polo mk5 gti does anyone know then fit it into my mk2 coupe??
pm'd
