adhesive for trim pieces
What is the best thing to reattach plastic trim pieces to the bodywork of the car??
Need it to be secure as last time i put them back on after doing some painting someone pulled them off and snapped them :-(
What have you used?? Needs to be nice and strong :-)
  • Views 1.4k
araldite might do the trick, when it sets its verry hard , but i wouldnt of thought when you pull it back off that it would pull the paint off. might leave alot of residue tho mind.
I'll add the car is a matt nato green pickup truck so it doesn't matter too much. Just want it to be secure enough to keep away would be vandals.
Only asking due to adhesives being so damn expensive and buying the wrong one for an application is annoying. Readin the backs of so many silicone adhesives over the wknd. Still no closer to what i need. So i thought i would ask if anyone had any experience that i could borrow.
Edited by demolover
Tigerseal
tigerseal for permanent (ish )
3m double sided trim tape is whats used from new
I used superglue before :lol:
But this was before a respray so I didn't car at all what it did to the paint.
Getting them off was erm, tricky?
