Wing mirror replacement on S reg polo
Hello, some yobs kicked off my wing mirror last week and i've had to buy a replacement from scrapyard, how do I take off the plastic on the inside of the door to get to the screws? I tried pulling it but didn't want to make things worse...
  • Views 886
just pull the black plastic triangle off with your hands, it will either break or not (pot luck really no concrete way of it not snapping) then theres 3 screws and a plug behind the door cards!
Thanks pepe, so to remove the plug I need to remove the door card?
Do you know how to remove the door card?
yes you do what i would do is un plug last so the mirror doesnt got crashing to the ground lol, ok you need a flat blade screw driver and prive the mirror switch out (from the door opener side) then prize the door pull handle cover off and theres 3 philips screws behind there undo them, unscrew the door pin and pull it of with a good yank!
Thanks! also I should have asked this in the first post but forgot! is it possible to replace the outside cover of the wing mirror, I bought one at a scrapyard that is red and the one that was kicked off (broken on the inside) is blue, how can I put the insides of the red in the blue casing.
Hope that makes sense but i've not a clue when it comes to cars!
