Poly gearbox stabaliser
I dont post on here very often, but wondered if anyone was interested in something I am putting together for a few guys over on UK_polos.
Basically, I got fed up with the engine moving around in the engine bay.... Its noticeable if you put the car in 1st gear and drive slowly... lift off the acclerator or push it down and you get a jurky bumpy feeling as the engine moves around in the engine bay. It does it at speed as well if you use the engine to brake.... the gearstick also moves all over the place!
This is caused by the gearbox stabaliser that VW provided being made of floppy rubber!
I have put together a conversion kit that alters the standard mount and stifens it up with poly bushes.
By preventing the gearbox from moving around so much you can avoid engine tramp under load and prevent wheelspin... effectivley allowing you to put more power down onto the road and not waste it..
The mount still isolates the engine from the chassis, it transmits a little more vibration, but nothing that you really notice.
If anyone is interested let me know.
I have designed it to fit the 6N2 GTI, but the same mount is used on the 6N and the 6N2 chassis, so pretty much any polo should benefit from this!
PM me if you are interested.
  • Views 500
I'm skeptical.
I'm sure that I've managed to stop breaking gearboxes by using more better-matched clutchplate springs. And I've seen standard G40 mounts tear G40 chassis legs.
You need a fair bit of 'give' in the mounts to prevent fatigue on a wide array of other parts,and id rather replace worn mounts than anything else.
For the first fraction of a second,sure,the torque goes into twisting the engine. But the force isnt wasted as long as you keep on the throttle,you'll get most of that compression back - only if you immediately lift off again will you loose it all into a bounce effect. And you wont do that if you're trying to shift it,as you will be if you're unleashing so much torque to challenge the standard mounts anyway.
It may be worth while on lower power cars,to give a more responsive feel.
But on my car (admittedly not the GTi you speak of,but still a 1.6 16v Polo),where traction can be broken in one second of throttle,i'll give it a miss until someone can counter my theories convincingly.
This one or other,there is already a group-buy feeler on uprated mounts in the relevant topic. Might wanna check it out.
