MK4 People
I took it off a MK4 in my local scrap yard, has a connection on the back of it, although i cannot find the wiring for it :(
?Just thought it would look better than having a blanking plate there :lol:, so what is it supposed to do exactly?
  • Replies 9
  • Views 1.3k
It's for disabling the passenger airbag when a baby is in the passenger seat.
Didnt know the MK4's had airbag disabling, unless you mean a golf?
It's not for the passenger side is it? Mine doesn't have a passenger airbag, I have the button, isn't it just the airbag light, it lights up when the ignition is turned on then goes off if there's no problem with your airbag, if it stays on then there's a problem.
Edited by H@wK£R
For some reason I've only ever seen these in early spec Mk4's, I'm yet to see a late spec with one.
And As far as I'me aware it lights up with the ignition lights and goes off once the engine is on just like a dash airbag light.
Edited by kwijibo_coupe
Yeh got one in my early spec one, it's just an airbag light. Tells you if you there's a problem with it or not.
I've put one in mine lol
Was in a early spec one :s
better than a blank one i suppose :)
Its an airbag fault code display button, when I messed up my coil it went on and i've now got a new coil, put it in and now just have to deactivate the fault code using VAG.COM :)
as above its the airbag light, its not an actual button
late spec 6ns have different clocks with the airbag light on there... hence why they don't have this one ?
Edited by polo_phil
My 1997 1.4 16V had one (Which was only a light, not a switch), but my 1999 1.4CL had the light on the dashboard instead.
The 1997 only had a drivers airbag, and the 1999 had drivers and passengers.
