Refitting OEM wheel (MK2)
Hi Guys,
My Polo has a TINY Mountney steering wheel that I really want rid of (horn doesn't work and its too small). I've got the original wheel but after prizing the horn press off, I cannot work out how to get behind the copper contacts to get the 23mm nut onto the spline.
Could anyone shed some light?
  • Views 888
I dont understand what the problem is,access should be simple.
Can you get pictures up?
Here we go.
Right,what you've done there is pulled off the plastic horn push's rubber cover,but left the horn push still in place. Quite how you've managed that is irrelevant,but you now need to get some wire hooks or something under the horn push itself,and pull that off too.
Sorted now, thanks mikey.
