Polo 1.6 16v GTI Rear Brake Setup+Exhaust System...
Add a 1.6 GTI Radiator to the list...almost new! covered 50k and is the same size as a VR6 one...will suit any mk4 polo or mk5 polo.
  • Replies 65
  • Views 2.7k
wen u say you have the gti head is that the red part on the top??????
that would be the rocker cover and yes i have one of those as well as a head... 8-)
i got one on my car allready (obviously lol) but want to get it re-painted so could do with one as a temp, how much?????
PM sent mate... :-)
Hi mate, how much for the rear brake set up? and what exactly does it consist of?
cheers Ed
Ed, i have posted the axle up in the brakes/suspension section...take a ganders...but it is a complete rear beam off a 50k GTI consisting of everything!
Axle, brake lines, discs, pads, handbrake cables, stub axles, calipers, carriers...EVERYTHING!
Yo sanj!
how much for the rear brake set up if I be cheeky & let you fit it for a small fee :)
Hope your well
Ash
Ash...sounds good mate...seein as its you, wouldnt cost you a lot...
£100 for the rear axle complete...i can deliver it to you too for nothing :)
PM'd
Rear axle now sold...
Exhaust system remains :)
is the exhaust standard? how much for cat back? cheers
its standard...Cat back is gone now...only have:
GTI manifold-£30
CAT/downpipe-£90
stil got the head ? take it its an avy
also my previosu question about the manifold has been confused what i couldnt remember was if the gti manifold had a cat as part of the manifold casting if that makes sense, nothing to do with o2 sensors ;)
Its an AVY head indeed...but the only difference between this head and an ARC is the extra oil pressure sender on the side of the head, you can use an adapter from demon tweeks to run both senders from one hole in the head...or blank one and run one...
As for the manifold- it bolts up like a 1.4 16v manifold...i.e. it has 4 nuts holding it to the cat/downpipe....so no the cat is not part of the manifold casting.
  • 7 months later...
Do you have a lambda sensor for a polo 6n2 gti.?
