Alpine Tweeters 75W Peak
Pair of Alpine Tweeters SPE-1002 - £20 collected
Spec - 4"(10 cm)
75W Peak
15W RMS
IMP. 4 OHMS
  • Views 203
do these fit any polo?
They're not tweeters. They're coaxial speakers.
sorry, not a massive ICE expert, i just know there the smalle speaker. they dont fit direct, some dash will need slight modification. only reason I'm not fitting is because i havnt got the time to fit them before i go to uni and leave the car at home.
Dan
Just to clear things up, these are the sort of speakers you would fit in your doors, not your dash. They would usually be used in rear doors, or in conjunction with a 6.5cm woofer and tweeter in the front door to make a 3 - way set up.
