polo genesis/gt conversion to break job lot now on ebay
ok so i bought a mk3 off a chap on here with the intention of putting it back on the road and tbo its better off being broken or used to covert yours into a gt,
cars done 98k in silver no mot or tax and would need to be trailered away
gt engine runs unsure of engine mileage under bonnet wiring very poor[spare loom included]
5 speed gearbox
painted red block
polished head[external]
polished inlet manifold
pipercross induction kit
8k chipped ecu
big oval upswept exhaust i think its stainless centre and rear and has been de-cated sounds quite nice [rattles bad]
rear coilover conversion on standard shocks[very stiff]
front shocks new [mot] lower swivel bolt loose [previous owner]
red front springs
new front brake hoses
drilled solid discs
14"vw passat steels in black
half stainless rollcage not even bolted or welded in
rear strut tower brace[red]
clear front indicators
gt steering wheel
gt arches and sill covers
no door strips
stripped out rear
brake master leaking so no brakes
no handbrake either prob cables or v-bad adjustment
i was told the engine has a uprated cam and had some head work ,i have driven it and it does pull good
engine oil pressure light comes on at revs but i tested with a gauge and it has bags of pressure so dash/wiring fault
i set the timing today and now idles loads better
bodywork is generally poor
laquer off bonet in one corner various dents on every panel
i want this car to go as one for someelse to use as i have no spare time to convert mine
I'm still waiting for the logbook to come through still and is currently sorn
I'm in the brighton area
could be driven away with trade plates if you like to run the risk but with v little brakes that would be hairy :shock:
any question call 07815952188 or pm me
thanks
il try get some pics up tommorow
Edited by bmwe30init
  • Views 587
is it gt box?
is it gt box?
no idea dude i assume so but i want to rid the whole car really
bump bump ending within the hour...
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOO.......OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO...OOOOOOOOOOOOOOOO!!!
I've been looking for a silver boot lid for ages!!
Shizzle :(
how muhc for the rear strut brace posted mate
do you have the exhaust manifold?? And if so how much??
Edited by Polo-junkie
