changing my steering wheel on my polo 97 for momo with boss
hi, i bought myself a momo steering wheel with a boss kit. how do i stop the air bag blowing up on me? is there anything i should be careful with?
  • Views 973
unplug battery wait 15minz then carefully take the steering wheel off
As above.... Disconect the battery before you start anything.
There's two allenkey bolts onthe rear of the original wheel wich need to be undone for the airbag to pull off, be carefull when pulling it of because there's a small plug at the back of the airbag wich just pulls out.
Everything else is straight forward.....
Make sure you get the boss and wheel sitting flush with each other, or your horn will keep going off. Also, you get two metal horn locater rings, one with boss and one with the wheel, use the one with the smaller lip, or your horn push will stick out and look daft!
Yeah make sure you undo the battery.
Edited by buster.g40
good call.... umm, also rember to setup the notch on the boss in the right place. so it knocks your indicator off once you straighten the wheel. had to toy with mine a few times to get it perfect. :)
