water leaks on 9N2 polos (the newest shape ones)
I think the newest shape ones are 9N2 aren't they? I've lost track of what "mk" that is!
Anyway my mum has one of these which she bought brand new from VW. Went round to see her last night and it turns out she's trying to get VW to take it back because she's had loads of problems with it. The biggest of which is that it has a really bad water leak into the passenger door (it's a three door). what happens is that when it rains loads of water seems to collect inside the door which pours out of the bottom when you open the door, if you leave it long enough then the door fills up until the water starts to leak out inside the car! It really doesn't seem to take much rain for there to be quite a lot of water in the door.
Just wondered if anyone else has hard or heard of similar issues with these polos?
  • Replies 9
  • Views 2.2k
yea my mums got 1 too but she has had no problems she lyks polos that much she getting the new one lol
I'm not familiar with the newer polos but with my old capris one of the first things I've been told to do is remove any grommits in the boot as they are bad for collecting water and rotting from the inside out. Its could be something similar here, a grommit that needs removing or a blocked drainage plug? If theres any exit holes, a wee bit of wire coathanger could dislodge any offending crud. Got to be worth a try :)
sounds like the drainage holes are blocked. I had this issue with my 9n.
Oh and for future reference, your mother's car is a 9n3. the 9n2 was the saloon 9n which we never got over here.
ah right.
yeah she said she's taken it back to VW several times now and they've tried unblocking drain holes. They said to my stepdad that they are sick of seeing the car back in so he said he's bloody well sick of having to take it back in! It's had problems with window motors, the radio randomly losing it's code and the passenger seat slider not working.
Annoying really because she's always had japanese cars in the past and has never had any trouble at all but me & my stepdad finally convinced her to buy a VW and then all this happens!
:( Build quality's taken a turn for the worse on the later polo's i've found.
My 09 golf's amazingly well built tho! They must've just forgotten to tighten all the bolts on the polo's!
yeah my stepdad has a four month old mk6 golf tdi and it's pretty good, he's had no issues with that so far.
Some of them have problems with the plastic skin behind the doorcard not stuck down correctly - All 4 of mine in the Fabia are leaking!
well my wife has a 2003 polo and i'm looking for a solution to this problem too seems like the ddor cards are the problem not sealed properly!! but i will investigate further before the mushrooms really take hold!! by the way my wife loves the car but she's away for two weeks now and all i have to do is change the cat, replace the rear wiper motor and find the leak what a car!!!! any advice on any of the above will be much appreciated!!!!
O.k been looking into the pronblem further seems the door cards are the problem as when i open the door the water runs out, now if anyone could point me in the right direction of how to remove them it would be much appreciated tried the search and got nothing! managed to get the rear card off to replace the back wiper motor so just the cat and the leaks to go!
