10m x 1.25m of carbon fibre fabric......,
ok, so i spent a small fortune on this stuff, but plans have changed and i want to spend my money elsewhere noe :D
so heres what your getting...
Beautiful top quality aerospace grade 5 harness carbon cloth in 280 gsm fabric weight.
This fabric is cut straight from the roll, and is not off cuts.
Cloth is from a 1250mm wide roll and comprises 10 sq m in total. It will be supplied rolled around a stout core and boxed as shown in the picture
These items can be used with all commercially available epoxy or polyester resin systems depending upon your application, which are readily available from such places as online boat chandlers, motor factors, model aeroplane shops etc.
A 5 Harness is a fabric where the weave runs over, over, over, over, under etc. It bends over complex curves better than either a plain or twill weave. A Harness frays less than a twill because a Harness generally has more weaves per inch than a plain or twill weave, so a Harness will hold together a bit better than a twill weave when handled carefully.
So, in general, if you dont have complex curves and dont care about aesthetics, a plain weave is the best option. If aesthetics are very important, generally a twill weave is selected. If you are making something with complex curves, a Harness is the best choice. And if aesthetics are important and you also have curves, then a Harness is often the best choice.
AND
a 6 litre epoxy resin kit comprising of 4 litres of epoxy resin and 2 litres of hardener, more than enough to cover this lot as it goes really far, and also a little pot of addative "F" which you add to the epoxy resin, this aid's with sanding and polishing, and also means that if at any time you have to leave the piece your working on, for any reason, and it cures, you can still apply the resin to the surface, where as without it, the resin would not take to it.
I'm asking £450 for the lot, it will also come with about 50 pairs of laytex gloves, 4 packs of 5 paint brushes, loads of cups for mixing etc, everything you need!!!
any questions, please dont hesitate to ask, or call on 07894643434, cheers, jon.
  • Views 327
WILL SELL FOR £45 PER METRE IF ANYONE IS INTRESTED, BUT WOULD HAVE TO BE FOLDED, ANYTHING OVER 3 METRES WILL BE ROLLED AND SENT IN A TUBE.
come on... does no one want this????
