wiring sub into 6n2
as above really, been trying to do it, and cant find no where to hid the cables, the normal places are realy tight,
also weres the best place to earth it, and some pics if posssssible
thanks
tej
  • Replies 8
  • Views 1.7k
which cables?
Hide the power wire in the channel that runs along side the car, the plastic clips out, hide it in there.
Earth hide it under the boot carpet.
I'm trying to run 4 gauge and it is pretty thick to fit into the side you have mentioned.
Also how did you earth it as I have tried it on the rear light but it didnt work at all.
I run 4 gauge down the side with no issues, along with speaker wire to the front doors and 2 sets of RCA's, and a remote wire lol.
I have earthed on the rear light, you can also use rear seatbelt mounts.
use a seat belt bolt not the tailight the metal is too thin and relying on a plastic fixing
just pull the trims off there is loads of room to hide the cables
yep as indy and ken said, theres loads of space, I've run 2 guage down the side with some 8 guage as well!!
yea indy, i took the side trim off, have you got any pics of your cabling, i tried earthing to the rear light and it didnt work !! !
Call Gugz. He's chillin tonight and he can give you some advice. :thumbsup:
safe ajay, I'm gna catch him on one of his rare days offf and get him to help a brova outt ! ! ! !
