Fitting aftermarket elec window regulator (6N)
The driver's side electric window regulator on my 1998 6N has failed (yet again!). The motor is OK but the wire cable has snapped. I had a lot of trouble winding the wire around the motor correctly the last time I replaced the regulator - this is not covered very clearly in the Haynes manual :x
I have looked at aftermarket replacement "Electric Life" regulators which come with their own motor pre-attached but notice that instead of having the electrical socket for the plug in the centre of the regulator (as on the OEM item), it is located at the top left (towards the wing mirror position). I reckon that this would mean that the existing wired plug in the door would not stretch far enough to the new position to plug in to the regulator's socket and it would seem pretty inaccessible for plugging in even if it could be stretched. The guy in the shop told me that scotch connectors would bridge the gap but from looking on the web these seem to be just little plastic clips and would not solve the lack of additional length of wiring to reach the plug or the accessibility to plug it in...this has left me scatching my head a bit...
Could anyone who has fitted aftermarket regulators as a replacement for the OEM items advise how the above problems can be addressed?
Are there better aftermarket regulators (i.e. closer to the OEM design)?
Or is fitting aftermarket regulators just a false economy?
Any responses greatly appreciated...
The best thing to do will be to get a new regulator from the scrap yard. Thats what i did and now works perfectly.
Or you could just extend the wires which would involve cutting them before the plug and getting some spade/bullet/butt connectors & crimps from halfords etc and some wire to just make the wires you have longer, not hard to do at all.
Dazza
Cheers - much appreciated!
