Hi... New member with questions...
Hi all... new member here on something of a fact finding mission...
I might be buying a 1.6 GL Polo next week... it's a MkIV I think from 1997.
Generally speaking it is in pretty good condition, it's done 96K mile but sounds pretty good (not too tappy) and has had regular oil and filter changes, brakes and clutch/gearbox seem fine plus it has newish tyres.
The only downsides seem to be body related...
1. rust in the bottom corner of the drivers door
2. rust around the rear wheel arch
3. dent in the sill (where is was incorrectly jacked)
4. drivers seat cloth has worn on the edge of the side cushion exposing the padding/filling
5. bottom corners of the windscreen, looks like water has got underneath but there there are no signs of damp/leaks/smells internally
I've offered £700 which has been accepted.
The body work I should be able to fix and expect these sorts of problems on a car of this age. A patch or some seat covers will hide the damaged seat. I'm not too sure about the windscreen though... is this a common issue.
Also where did the GL fit in the model range, it seems fairly well specc'd with power steering and central locking. Finally is the 1.6 engine generally reliable, spritely and still relatively economical.... or is this a model/engine to avoid.
Any tips would be gratefully appreciated...
I really like these Polo's and prefer them to ugly Fiesta's so I hope to be around for a bit.
Edited by BusterDAN
  • Replies 11
  • Views 1.6k
alrite mate...welcome to the horde :-D lol
well all those problems seem pretty standard with the 6n's, not too sure about the windscreen one though, pictures of it would have definately helped,but maybe it could just be a seal or something??
as for the 1.6, i recently wrote one off and had another before, they're not bad too drive and the engines are easily modified. to be honest though if you want power, hold off and get a valver as you would have to quite a bit too the 1.6 to get it to the same power level as the valver. economy wise, its only as good as you drive it, I've now got a 1.4 and that seems a lot better fuel wise and 1 years tax is the same as 6 months on the 1.6.
the price youve offered is about right, it now just depends on your plans for it as to wether or not its worth it, if its just a daily run around, get a 1.4
Cheers Sean... the windscreen looks like a misting under the glass... just in the corners.... about an inch or so to where I guess the seal is, might just be that the drain holes are blocked and rain water etc is pooling in the corners.
Yeah I am only really looking for a run about but this is the cleanest (despite the issues list) Polo I have seen.... some have been really poor... I'll mostly be doing motorway miles (about 60 miles a day) so the thought of a gutless 1.0L is scary but I guess the 1.4 would still be good. I'll have to compare them... also is there much of a difference between the GL and CL model?
iv got a 1.4 cl and it seems to have most of the optional extras, appart from things like aircon. and also i have ever one of the problems you have just said about lol if your not happy with the seat, k3 golf seats fit in the front perfectly. if it has a sunroof, retract it and look at the lip at the front of the roof to check for rust as mine seems to be going badly there! check the gearbox for whines and noises as these also often go. is it a 3 or 5 door. and to put it into persepective i paid 1300 for my example with coilovers, so you seem to be geting a decent deal. what colour is it?
Jon
Jon
Thanks Jon for the tips... I've not had a test drive yet... just had a look around it but when I go back I'll give it a more thorough going over. It's a dark Metallic blue which looks quite nice.
By the way what's all the 6n business I have seen mentioned, is that the way VW designated the MkIV Polo model?
Does the stereo also have a standard ISO connector?
the 6n is the mk4 chassis number...the mk5 is the 6n2.
sounds good but with what youve said id get a 1.4, theres quite a few on ebay at the minute and some nice ones in the for sale section. i enjoy driving my 1.4 as much as my 1.6, theres not that much difference.
as for the GL / CL thing, i actually dont think theres a difference at all, maybe different seat pattern lol. might have something to do with ABS or not, I'm not sure
Cheers Sean, I'll checkout Ebay for some 1.4's and see if there is anything nearby worth looking at.
Looks like I am going for the 1.6... as I haven't seen anything else that takes my fancy.... had another look around the car today although still not had a test drive yet because I am going to have buy the policy first... should pick the car up early next week.
good choice. i have a 1.6 with 137500 miles on and takes me and my mates to shows all over the country. very reliable and on motorway journeys with 4 people and as fully loaded as you can possibly get a polo still does nearly 50 mpg.
and welcome to the club
Thanks for that... well tonight... after alot of insurance messing around (mirroring of NCD etc from my other car etc) I became the proud owner of the 1.6 GL mkIV Polo.
It has a few issues which I will post about but nothing major... bottomline though is that this seems like a sound little car and runs really well.
One of my first issues is the clutch pedal.... it is soooooo stiff... is it hydraulic or cable... so I'm thinking this needs attention quite soon.
Second thing is that I only have one key... are second keys fairly easy to source/cut at a reasonable price?
Thanks for your help.
Just out of interest...
...after alot of insurance messing around (mirroring of NCD etc from my other car etc)...
...what do you mean 'mirroring'?
The key has an imobiliser chip it in. costs about £25 to get a key and chip copied.
Edited by ben_reza
Basically some insurers (very few) allow you to mirror across you NCD to a second policy on a second car but there are lots of conditions... this is where I was cought out... however I then got a really good deal from Churchill.... Internet Quotes are fine but to get a more personalised policy speak direct of the phone is the only way.
I didn't think my Polo had any kind of immobilser... but it does seem to have the remnants of an alarm system with a LED on the dashboard, but non of this seems to work.
If the current key does have a chip (is there anyway to tell?) then how is it possible to copy it... do I need a code for example?
Dan
