6n2 GTi Drivers side electric window
My drivers side window is starting to bug me, it will roll all the way down, but when it comes to putting it back up, it either doesnt come up at all unless you open and close the door a couple of times, or it will wind up a little way and go back down again.
Also noticed when the window is up there is a rattle coming from inside the door.
Anyone else got this problem or had this problem? any ideas on how to resolve it would be most appreciated :D
-Chris-
  • Views 640
Hi yea it is the window switch it self i bet, as i had similar problem. I took the switch apart and cleaned the little metal plates inside as they were corroding. then glued it back together and works fine now. check the wiring first thow behind the door!
Edited by petew
