mk2 polo cambelt?
where can i get a cambelt and water pump for a mk2 1.3 coupe s? just looekd on ebay for the cambelt couldnt find one, and the waterpump is £35 is this a good price
GSF? ECP? its the same lump as the normal 1.3
you should find the parts almost anywhere
any good motor parts shop , halfords , gsf , ecp
£35 is a little steep for a pump...did mine last year , was £20 odd for the pump and £3 for the belt with a halfrods trade card
i have a new VAG square tooth water pump in the shed doing nothing, £25 posted. much better than the dross you'll get from euro's or halfords. PM me if you are interested
Edited by polopete
you need to be carefull if your cars a late spec mk2 as there are 3 types of teeth across the mk2-3 range and you then need a water pump with teeth to match!
Square tooth large gap - late mk2 and early mk3s
rounded edge tooth - early mk3.
Square tooth smaller gap - most common on mk3s
i learned that hard way with my GT :-( as it has a late mk2 belt set up on it so it was 3rd time lucky.
ETKA gives you the engine number and what belt it should have but very occasionally it lies.
I got a late mk2 polo s(E reg) and it has got square tooth large gap. Who ever changed the water pump before me never knew this and chewed the timing belt up. Managed to get replacement off ebay £25 for the 2. :D
