Later Mk2 Seats Fitted - Release Handle on the Wrong Side.
As you may guess from the title, i have some seats from a mk2 coupe S and have fitted them into my mk2 classic. I have read that the earlier mk2's have the release handle for the seat moving back and forth on the opposite side form the later mk2's.
This is the problem i have, is there a guide on how to change it over?
Is it easier to change the locating tube in the car rather that the whole release mechanism on the seat?
Or easier to change the bottom seat frame (i still have the old seats)?
Danny
  • Views 708
euroderby/vic did this with some gt seats i think, might be worth asking him for advice?
thanks
will
Thanks mate, i had a go last night, and it's fairly easy.
The front clamp that holds the handle mechanism in place is just a case of unscrewing and re-fitting on the other side as there are pre-drilled holes already there. The rear 'clamp' required cutting off and re-welding on the other side. Obviously you need to swap the handle from the drivers seat to passengers seat and vice-versa. THe drivers seat rear 'clamp' is different to the passengers but fairly self explanatory when you see it.
Danny
