Bready arch flaring
I'm seriously considering getting my rear arches flared to fit some nice wheels, maybe 6j? Anyone had it done?
Edited by Polo Will
  • Replies 8
  • Views 1.3k
Loads of people have done it. Some use a rubber mallet, others weld on a replacement wing on top to add width.
Some even chop the thing like a coupe arch. http://z8.invisionfree.com/POLO3/index.php?showtopic=8829
Cool, thanks for that. The lip bit seems to be the problem so might find a way of getting rid of it or at least moving it out the way.
If your looking for a slight increase of width for a 6J wheel with a standard vw et38 offset someone with skills should be able to get up to an extra inch without any real noticeable butchery to the arch. It's not like a coupes rear arch it's very ridged so you can't necessarily roll it.
I've even heard of someone using a bottle jack to move the whole arch with panel out but again it takes skill and knowledge. I don't like the idea of bending the lip in or messing with things myself because generally it can end up easily looking shit and catch water. This guy managed to get 7J et20 (i believe)classics on this square without ruining the lines of the car...
Edited by MacColl
That's a really nice car. Cheers for the info. I'll probably be getting it done at my local VW specialist place. Just need the tiniest bit of room so the lip doesn't catch the tyre.
Aren't the rears in that photo 8J? It's hard to tell...
I've recently had all 4 arches on my mk2 breaddy flared by a fair bit - at least 2" on the rears and 1" on the fronts.
The main problems you will have are:
1. The front arches clip onto plastic arch liners - these will have to be removed. The mounting points for these will cause a wavey effect if you try and roll them which can only be fixed with a skim of filler.
2. If you want the rears to look natural you will have to split the panel back to the rear light, and weld in new metal into the gap. You will then need to space out the bumper mounting point otherwise it will look as if the bumper has been dented into the panel.
Pre-paint pics:
- Henry
Edited by onelegout
I was thinking of just getting the back done, the front seem to be able to manage 6j wheels without any rubbing, however if it's going to be complicated / expensive then I don't see much point.
i had a set of p slots, which are et38 and 6j and they fit no probs, and that was with a fat tyre, 185,60s go for a slight stretch, say 175? and i reckon they will fit nice under the rear arch, with minimal fuss
Maybe theres slight differences between the mk's or even within the mk's because I've heard mixed views on whether 6J et38's will fit. I'm still rolling with my 4.5J steels lol.
