Clocks Squeak
mk 3 coupe with cl clocks,
they kind of rattle/squeak, sounds like theres play in the four little clip things that hold them, also appears to be some kind of foam around the front where they meet the dash, but only on the bottom, should it be all the way round?
how do i remove the clocks if i want to also? push the pins in or something?
cheers
Ben
  • Views 612
Popular Days
You are supposed to use a pair of those din radio tools to remove them.
Can be done without if you have long thin fingers.
Remove the light switch by pulling it out. Using a torch you should be able to see the side of the clocks were the 2 latches are.Try pushing them in.If you can get that side to move then youll be able to pull the clocks towards the wheel.Depends what wheel you have on as to wether youll be able to get the clocks thru the wheel without removing it
