Where can I get a rear "show" strut brace from?
Hello people.
Can someone please tell me where I can get a show strut brace from, as in thick and highly polished/chrome finish.
It doesn't have to connect to the top of the suspension strut, as I'll be bolting it into the sides of the turrets using high tensile bolts.
I spoke to my bodyshop guy earlier, and he said it would be very expensive to have one made up, and would be best off buying a ready made one, but no one ready makes the thick show braces that I know of.
Has anyone got a rough idea of a price from a fabricator for something like this:
P.S. I hope Jon doesn't mind me using his pics :)
  • Views 1.6k
Was thinking maybe to just get some cheap alloy hollow tubing, and then just get somewhere to weld the connector plates on the edges?
As You said, measure up and get some hollow stainless/aluminium pipe (ebay) and take it to your local engineering place.
Mate of mine done his, think the pipework cost him the most, probably coming in around the £35 mark then took it down to our local shop and guy made the flanges and welded them on for £20
Thanks mate appreciate the response! I can get some tubing for about 10 quid for a metre.
Highly polished, 1.5mm thick wall but 3 inch in total diametre. The guy said it won't dent easily etc, so should be okay!
That's a roll cage, well, a show cage more likely. A strut brace is a simple single car between the rear turrets.
The car above has both a show cage and a strut brace installed.
I'm on about getting something like the brace made up, which I've zoomed in on in the second picture.
Edited by indy231
