repair panels (now with pics)
Anyone know if you can get a repair panel for the spare wheel well on 6n polo as mines a little rotten on one side
Edited by dubbegood
  • Replies 9
  • Views 1.4k
Try Hadrians. Failing that it should be easy enough to find a good one in a scrap yard and just cut it out.
bump now with pics
on etka theres only a part to replace the whole of the boot floor witch i would expect would be a massive job really. cant you just take it to a body shop have all the rust removed and it plated up from underneath and sealed
I'm with heartagram on this one. If you can get a complete tub chopped out the boot floor of a scrap 6N and have a bodyshop weld it in for you, that will be just as good as buying new if such a panel exists.
It would be easier to weld a couple of patches in and seal them up.
sand it down it just looks like bubbling to me that could probally be sanded down and skimmed with filler and be fine :)
one is just bubling and other has gone right through metal is paper thin around it. might pop to scrappy tomorrow and see if i can get a spare wheel well chopped out of another 6n and use that to repair the wheel well
Edited by dubbegood
just a neat plate and seam sealer will do fine...aint worth chopping whole thing out
getting a bit fed up of finding holes in the floor of my polo got three bungs in the floor pan that have rotted out and this lot in the wheel well
