Whats best engine
I've looked into getting a diesel mk4, but how are the 1.4 and 1.6 compared to it. I'm just looking at economy, servicing and so on.
regards
Greg.
  • Views 948
If you want official economy figures:
1.9 Diesel - 50MPG
1.6 Petrol - 41MPG
1.4 Petrol - 44MPG
1.4 Petrol (16v) - 40MPG
Surely the extra cost of diesel would cancel out the extra few mpg you'd gain???
Plus the noise must be a factor!?
My lasses diesel was only £300.
The mpg figures are flawed,because they're all tested the same - yet you dont drive them the same.
The 1.6 is thirstier at the same rpm but you use less. It has more low down torque due to the long stroke leverage,but its not efficient at high revs because its long stroke creates high friction..
So drive a 1.6 to its strengths,it can use less fuel than a 1.4 which takes more of a kicking to shift.
I've had over 70mpg from a bike carb'd 1.4 but i got even better efficiency from a 1.6,though i drove it at idle in 5th most of the time. Because it could.
I cant speak for the diesel,i dont do diesels. But the non-turbo 1.9 had enough to move the Caravelle minibus,I'm sure you can run it unstressed in a Polo. If not,it wont be remarkably efficient - the lower the revs,the less friction/heat/wasted burn etc you're loosing.
