1600 Mk2 Squareback Van...
Make: VW
Model:Polo C
Year/Reg: F plate, 89'
Mileage: 100k
MOT: Expired
Tax: Expired
Good points: Good solid car, had MOT up until begining of yr.
Bad points: Unfinished
Price: £250
Contact details: Pete - 07530540743
Having to sell my squareback project as I've nowhere to keep it anymore.
Its a Mk2 squareback with 1600 ABU sat in it, 5 spd box etc, it has coilover rear suspension, -80mm springs n shocks on front, I have painted the full shell in red oxide primer (going for ratty look) including the inside rear of the car, which is stripped out,. I fitted a brand new set of van panels and the rear arches are pulled to take some phat rims (I had 8x13's on it at one point) tailgate is smoothed, as are the rear quarters, I intended to run the car on R6 bike carbs, which are included as is the R6 fuel pump to suit.
Things that need doing -
New front wings fitting/painting
Rear window fitting, boot catch fitting etc.
Spare wheel wheel cut out, so need a piece fitting in.
Gear linkage connecting, starter motor fitting and wiring harness connecting.
Manifold making for bike carbs.
Needs exhaust manifold and full exhaust.
Few other minor bits... wipers fitting etc...
Pics are before I finished painting the full car....
Edited by milko
  • Replies 9
  • Views 624
hi there, would it be possible to fit the engine and gearbox to a mk2f? and will there be space for a turbo afterwards?
thanks
Yes, the ABU is small block so physically the same as all engines that come in standard polos.... and yes there would be room to turbo it but not sure how you would go about that... ie what injection and ecu you would use....
are the wheels included in the sale? may be intrested...
No, rims are already sold.
would you sell the rear window blanks seperatelly bro?? thanks tom
Waiting on someone paying a deposit.... if falls through, may break....
this sold yet matey?
ye, I'm just in the progress of organising a trailer to pick it up
