Mac audio 12" sub with alpine digital amp
As above
Sounds good!!
£75
EDIT:
Alpine MRD-M300
150 watts RMS x 1 at 4 ohms
300 watts RMS x 1 at 2 ohms
MOSFET power supply and output stage
STAR Topology for cleaner sound
low-pass digital crossover, 30-200 Hz, 24 dB/octave
variable subsonic filter (15-50 Hz in 5 Hz steps)
parametric EQ variable from 30-160 Hz
Bass Compensator enhances low-end definition
top-mounted digital control center with cover
time correction 0-10 milliseconds in 0.5ms steps
phase correction 0-180 selectable
digital readout
detachable front cover
blue power LED
delayed turn-on
requires 8-gauge power and ground leads wiring and hardware not included with amplifier
speaker- and preamp-level inputs
gold-plated terminals
8-5/16"W x 2-11/16"H x 11-1/2"D (10"D without front cover)
Mac Audio 12" absolute300 Subwoofer
Key Features
Car Speaker Type Component
Elements 1-Way
Car Speaker Function Subwoofer
Size 12"
Nominal Power Handling 270 Watt RMS
Powered Non-Powered
Peak Power Handling 620 Watt
Frequency Response 20 Hz - 2 kHz
Sensitivity 92 dB
Impedance 4 ohm (Dual Coil)
Edited by ben_91polo
  • Replies 24
  • Views 785
pics.? specs?
pics.? specs?
Ill go take some now for you.
Ben
Spec now up. Photos will be in few minutes.
Photos now on!
bump
Would you take 30 posted for the amp?
not splitting, and no the amp is worth more than that anyway.
Ben
swap for an alpine head unit ??
what spec ect?
35 posted?
x
35 posted?
x
Would cost nearlly that to post!!
35 posted?
x
Your joking right? wouldnt cost more than a tenner.
it would easily cost more than a tenner.
It clearly says £75 at the top so why would i take 35 including postage??
Either way it isn't going for that.
Serious offers only
sorry mate late reply, its a cdr 911a i think will get exact model number tomorrow, works mint all tilt front works fine 60x4 wtts
bump
this still for sale?
will you take 60? i live in derby so no postage.
yeah you can have it for 60 mate
bump
£60
Bumppppppp
ttt
still have this
£50 collected
no offers
bloody hell £50 and still no one?
Would you consider £40 posted?
No i'd consider £50 + P&P
