Mark3 saloon
As title, just broken a saloon for a good friend of mine.
They are looking to get some money back from what the car owed them.
Theres plenty available, except most of the running gear.
Fuel tank: Has surface rust around the filler neck, but whilst off a car can be sanded back and treated. Solid everywhere else. £15
Front and back blue carpet sections: £10
Front and rear seats. Finished in blue CL check cloth. Drivers seat doesnt tilt forward (easily fixed with a new cable), and rear backrest has a split on one of the headrests. Its faded quite badly, but the front seats can provide subframes for some after market seats and the rear bench could be retrimmed: £15 the lot or offers on what you need.
Full set of blue doorcards (suitable for saloon and coupe): Need a clean up, but in good nick. £15
SPi in line fuel pump and accumulator: £15
Front struts supplied with no brakes, and original springs and dampers. One will need a tie rod end removing from the arm of the strut: £15 pair (will split)
Beige headlining: £15
Dashboard wiring looms (with original factory radio plugs still intact!): £10
SPi engine bay loom: £5
Headlight loom: £5
Theres loads more, I'll be here forever writing it up.
If you need something, reply here, or PM me and I'll get back to you with its availibility and condition.
Cheers!
K
  • Replies 35
  • Views 1.8k
is it four or five speed?
Still got the gearknob?
will come collect, how much?
Ben
hi karl,
whats the back bumper on it like?
if its fairly mint what you looking for it collected.
cheers :-)
I think it was a 5 speed, either way, there should be a gearknob around the unit. I'll grab one of each next time I'm up there.
Sorry, rear bumper was mullered by a previous keeper.
cool let me know when i can collect and i'll come get it.
It was a 5 speed i'm after.
Ben
got a glovebox? and know if it'd fit a fox, without having to replace the whole dash, cuz mine came with no glovebox door on it :[
Dashboard wiring looms give you 8 pound posted :D
Glove box conversion kit, I can do for £10 posted. Thats everythign you need to fit it to a base spec dashboard.
Dashboard wiring loom I'd ideally like £12 posted.
hi karl
I'm after wings, bonnet, thin bit of metal underneath the grill
also drives door
prices and condition?
can collect
cheers
No doors, as one was bent from a break in, and the other was badly damaged around the lock from another break in attempt.
We do have a passenger side front wing. Needs a damn good t-cut as its gone the obligatory pink, but is in good overall condition with no dents or rust (that I could see). Passengers wing was scrap as the arch lip had rusted away underneath the arch trim.
The bonnet is a NOS VW replacement that has only had the top side painted red. The underneath is still in the original black primer, complete with part sticker, as the saloon had had a front end knock at some point in its life. Again, its pink, and has 2 dents in the outter skin, but I'm sure they could be easily removed.
Front panel was very crusty due to stone chips being left unattended, so that along with the doors was scrapped.
In light of them needing a polish, £20 for the passegers wing and the bonnet.
are the front indicators orange or clear? would love if clear
How much and what condition for the rear clusters posted?
Also do you have the seatblet clips ?
Indicators are orange I'm afraid, car was 100% standard.
Rear lights good nick, £30 posted?
Describe the seatbelt clips to me so I know what part you're refering to.
what shocks does it have? also what condition they in?
after a pair of rear uprated shock inserts
As said, sorry to disappoint, but it was 100% standard, so the suspension (bar front struts) was chucked with the shell.
did it have clear indcaters
and pics of the seats please
No clear indicators, and can get pics later on in the week for you.
hi mate how much for the radiator and the coil pack?
cheers lawrence
hi mate, am after a front bumper. what sort of condition is it in? and chance of postage? if so how much?
thanks
you still got the arches and strips? ill take them off you if good con. PM me the price :D
PM'd
I'll take the doorcards for my loon, currently running none and its starting to get nippy :)
i blew my engine up t'other day but i will be running my new one by next friday, coud i come and pick them up then?
thanks jamie
cheers lawrence
Radiator had also been removed along with the engine :-(.
Coil pack £5 + P&P
thanks
Front bumper was faded, but the brackets were all in good condition, and no major scrapes or gashes. £10 Postage might be tricky due to size, however.
If you mean the door rub strips, I have those, yes, £5 for the full set. Arches, it only had the front 2. £5 each.
thanks jamie
Sure thing! PM me near the time, or I'll forget, and I'll give you the postcode for where the parts are. £10 for the set alright?
how much for the drivers side rear light please
thanks nick
