engine coversion
ok as a few of your probably no i got a 1.0 coupe but i might be buying a 1.3 tomorow for the engine and box any 1 no how hard they are to convert also are the shafts any different from my 1.0 the engine is the 1 that has the circle style filter on the top any help would be good thanks dan
Edited by danbinty
  • Views 1.2k
Everything is a straight swap, driveshfts, gear linkages. The anti roll bar might be different if going to from 4 speed to 5 speed box, but thats about it i think.
I thought the power difference between the two engines was next to nothing. You would be better off trying to source a GT conversion from somewhere and chuck that in instead.
May not be doing it for power, perhaps he's engine is cream crackered? and at least it will be 5 speed
Yeh 5 speed will definatly be an advantage.
15 extra horsepower is considerable when its on top of a 40hp engine. And the extra torque is a greater percentage still.
And maybe the standard 1.3 hasnt been thrashed yet? And was easy to get hold of?
All i know is that he'd get more power just as easily but for less money if he'd read the info in the engine forum instead of posting an inevitably popular question in the wrong section.
i am new to the forum so sorry about puttin it in here i wasnt to no and my engine is only on 73k but it tapaty and the car has come up cheap with the 1.3 in so for what it would be to do the conversion i might as well do it
Tappety is usually an oil problem,either not enough of it,or its old oil and needs changing,or a worn/blocked oil pump.
Or if its only one tappet,a replacement one.
But if the tappets are worn (over 500,000 miles or poor servicing),then the camshaft will be too.
I do hope the donor car is cheap,because the 1.4 engine that fits typically costs £100.
