TSR 280mm brake conversion kit,also MK3 VR6 calipers
TSR Performance 280mm disc conversion kit for all 4 stud VW's,comprises of the discs (only approx 100 miles use as calipers were catching on the rims) and spacing brackets (this kit uses your original calipers). This kit was £289:00 new from TSR but has been discontinued.....£100 no offers as cost me more than that
also good pair of VR6 front calipers with nearly new pads.......£40 also no offers as cost me more
collectoion from hertfordshire or can meet anywhere between herts and the lake district on the 19th sept onwards
  • Replies 9
  • Views 470
what is the spacing of the hub mounting holes on the adaptors as they wont fit early polos (mk1-3) if they are circa 96mm
i will measure and post the results but they have already been on a mk3............
cheers dude =] much apprieciated! will help prospective buyers
sensible offers as need these gone, swap or take wheels in p/ex no bigger than 15's
finishing on ebay tommorow bidding starts at £50 with no reserve......
It's obviously a kit desigened for mk1 golfs and sciroccos dude, you can see the adaptor spacing has stepped down ;)
as previously stated it came off a mk3 and was only sold to me as the calipers rubbed on thealloys that the chap was running......
hey man, did you sell these on ebay in the end?
if not can you measure the discs? are they definatly 280mm as tsr did a 270mm conversion with VWIIs which fitted under 14 inch alloys?
i may take them off you if they are the 270s
cheers mucker
will meaure them later and get back to you...
