6n2 gti breaking
Hi guys finally got a full list of the remaining parts i have left off my gti 2001 6n2 polo. Theres quite a list but it will save wasting peoples time trying to find out what is left. All parts are open to offers with the exception of the alloys and gearbox. If anymore information is needed on any part just drop me a pm Thanks.
Power steering pump
Alternator
Aluminium auxiliary bracket
Exhaust manifold
Ignition coil
Starter motor
Evap canister
Exhaust heat shield
Oil separator
Full cylinder head( cams, rocker cover etc (AVY)
Front calipers
Pads and discs (done only 700 miles)
Drivers front hub
Standard shocks and strut tops
Wietec 40mm lowering springs
Dark grey carpets and underfelt
heater box(heater blower,flaps, heater matrix etc)
Catalytic converter
Bonnet
Boot lock
Drivers door
Subframe
Steering Rack
Anti roll bar
Gearbox Rebuilt by vw 1000 miles ago (£300)
Driveshafts
Door seals
Boot carpets
GTI BBS alloy wheels (£250)
Clutch cable( 700 miles old)
Engine fan
Air con condenser
Geniune t belt kit and water pump (700 miles old)
T belt covers
Lambda probes
Passenger side door lock
Alarms horn
High and low tone horns
Xenon level sensor
Steering cowl covers
Slip ring
Hazard light switch
Brake light switch
Interior alarm sensor
Interior mirror
Glovebox
Plastic shelf beneath steering wheel
Front wiper motor and linkage
Steering column
4 GTI speakers
Geniune radio
Cd player
Master cylinder and reservoir
Brake servo
Water housing& thermostat
Power steering pump reservoir
Geniune vw clutch kit( 700 miles old)
Engine and gearbox mountings
Flywheel
Convienance ecu
Aibags
P/s window motor
Air con climatronic control panel
Engine ecu (AVY)
Edited by polo gawa
  • Replies 152
  • Views 7.4k
What colours the bonnet? and whats the condition like?
pmd :-)
Do u have door pins and roof clips (not the lon ones down the gutter but the 4 smaller clips/flaps? Cheers!
have you still got the cupholders the ones on the centre console bit
Hi How much for the weitec springs?
dont have either of the bits your looking guys sorry
Edited by polo gawa
bump
cupholder
splitter
boot spoiler
bumpers
indicators
how much for each ?
cupholder
splitter
boot spoiler
bumpers
indicators
how much for each ?
dnt have any of that
Do you have the exhaust from the cat back? If so how much posted? Cheers.
dont have them only have cat
do you have the front head lights or fogs n grills? thanks
pm sent
Dont have mate sorry
Front mats?
Front mats?
sorry dont have
Hi mate, what colour is the car, intereseted in a few bits if the colours right
May need a driveshaft as well
PM'd
CAR IS RED IN COLOUR HAVE BOTH DRIVESHAFTS
Do you have the following:
Glovebox section,
Drivers side under dash tray,
Centre console.
If you do, please let me know how much inc. delivery for those three please. 8-) PM might be best as i hardly check back to posts.
Bump
Power steering pump
Alternator
Exhaust manifold
Ignition coil
Starter motor
Evap canister
Exhaust heat shield
Oil separator
Front calipers
Drivers front hub
Catalytic converter
Bonnet
Boot lock
Drivers door
Subframe
Steering Rack
Anti roll bar
Driveshafts
Door seals
Boot carpets
Engine fan
Air con condenser
T belt covers
Lambda probes
Alarms horn
Xenon level sensor
Slip ring
Hazard light switch
Brake light switch
Interior mirror
Glovebox
Steering column
4 GTI speakers
Geniune radio
Cd player
Brake servo
Flywheel
Convienance ecu
Aibags
P/s window motor
Engine ecu (AVY)
Throttle body still avialable?
no throttle bodys sold
bump
