6n2 gti breaking
3 or 5 door model?
  • Replies 152
  • Views 7.4k
hi, do you have the dash? dash mounts and the heater controls?
pmd
bump
have you got the gear stick?
jon
jon
pmd
Would I be able to get a pic of the wheels?
And where abouts in NI are you located? ;)
Lisburn mate will get you some pics if you want
Hi guys finally got a full list of the remaining parts i have left off my gti 2001 6n2 polo. Theres quite a list but it will save wasting peoples time trying to find out what is left. All parts are open to offers with the exception of the alloys and gearbox. If anymore information is needed on any part just drop me a pm Thanks.
Power steering pump
Alternator
Aluminium auxiliary bracket
Exhaust manifold
Ignition coil
Starter motor
Evap canister
Exhaust heat shield
Oil separator
Full cylinder head( cams, rocker cover etc (AVY)
Front calipers
Pads and discs (done only 700 miles)
Drivers front hub
Standard shocks and strut tops
Wietec 40mm lowering springs
Dark grey carpets and underfelt
heater box(heater blower,flaps, heater matrix etc)
Catalytic converter
Bonnet
Boot lock
Drivers door
Subframe
Steering Rack
Anti roll bar
Gearbox Rebuilt by vw 1000 miles ago (£300)
Driveshafts
Door seals
Boot carpets
GTI BBS alloy wheels (£250)
Clutch cable( 700 miles old)
Engine fan
Air con condenser
Geniune t belt kit and water pump (700 miles old)
T belt covers
Lambda probes
Passenger side door lock
Alarms horn
High and low tone horns
Xenon level sensor
Steering cowl covers
Slip ring
Hazard light switch
Brake light switch
Interior alarm sensor
Interior mirror
Glovebox
Plastic shelf beneath steering wheel
Front wiper motor and linkage
Steering column
4 GTI speakers
Geniune radio
Cd player
Master cylinder and reservoir
Brake servo
Water housing& thermostat
Power steering pump reservoir
Geniune vw clutch kit( 700 miles old)
Engine and gearbox mountings
Flywheel
Convienance ecu
Aibags
P/s window motor
Air con climatronic control panel
Engine ecu (AVY)
Hi mate,
Do you have the exhaust system? Cat back is what I'm after if poss.
Anti roll bar how much ?
And do you still have the hand brake ?
Hi mate,
only have cat left
Payment sent for discs and pads
Power steering pump
Alternator
Exhaust manifold
Ignition coil
Starter motor
Evap canister
Exhaust heat shield
Oil separator
Front calipers
Pads and discs (done only 700 miles) =SOLD
Drivers front hub
Catalytic converter
Bonnet
Boot lock
Drivers door
Subframe
Steering Rack
Anti roll bar
Driveshafts
Door seals
Boot carpets
Engine fan
Air con condenser
T belt covers
Lambda probes
Alarms horn
High and low tone horns= SOLD
Xenon level sensor
Slip ring
Hazard light switch
Brake light switch
Interior mirror
Glovebox
Steering column
4 GTI speakers
Geniune radio
Cd player
Brake servo
Flywheel
Convienance ecu
Aibags
P/s window motor
Engine ecu (AVY)
Power steering pump
Alternator
Exhaust manifold
Ignition coil
Starter motor
Evap canister
Exhaust heat shield
Oil separator
Front calipers
Drivers front hub
Catalytic converter
Bonnet
Boot lock
Drivers door
Subframe
Steering Rack
Anti roll bar
Gearbox Rebuilt by vw 1000 miles ago (£300) = SOLD
Driveshafts
Door seals
Boot carpets
Engine fan
Air con condenser
T belt covers
Lambda probes
Alarms horn
Xenon level sensor
Slip ring
Hazard light switch
Brake light switch
Interior mirror
Glovebox
Steering column
4 GTI speakers
Geniune radio
Cd player
Brake servo
Flywheel
Convienance ecu
Aibags
P/s window motor
Engine ecu (AVY)
Hiya mate, thanks for selling us the gearbox today :) looking forward to recieving it.
Just wondering how much you want fo rthe xenon level sensor, the boot carpet (is it dark grey?)
then do you have the cup holder tray thing and a parcel shelf... if so how much?
can send you the money today, then you could post all together with gear box?
Many thanks
Holly
pmd
u got the gear knob still?
do you have the drivers side lock i need the paddle?
dnt have
u still got the clocks mate??/
dont have clocks
I presume the 'Plastic shelf beneath steering wheel' is the little cubby hole?
seen here...
Do you also have the arrowed piece of dash trim?
Are they the dark dark grey, almost black in colour?
Thanks.
seen here...
Thanks.
yeah dark grey in colour . Dont have piece arrow pointing too but do have shelf with the wee cubby hole in round the fuse box also have the steering covers
How much for the cubby hole posted then...?
