6n2 gti breaking
How much for the cubby hole posted then...?
pmd
  • Replies 152
  • Views 7.4k
Bump
do u still have the alloys
pmd
bump
have you sent my brakes dood?
yep should be with you any day soon
do you have the breather hose? the hose that connects into the air filter.
thanks
nope dont have
bump
bump
bump
Power steering pump
Alternator
Aluminium auxiliary bracket
Exhaust manifold
Ignition coil
Starter motor
Evap canister
Exhaust heat shield
Oil separator
Full cylinder head( cams, rocker cover etc (AVY)
Front calipers
Pads and discs (done only 700 miles)
Drivers front hub
Standard shocks and strut tops
Wietec 40mm lowering springs
Dark grey carpets and underfelt
heater box(heater blower,flaps, heater matrix etc)
Catalytic converter
Bonnet
Boot lock
Drivers door
Subframe
Steering Rack
Anti roll bar
Gearbox Rebuilt by vw 1000 miles ago (£300)
Driveshafts
Door seals
Boot carpets
GTI BBS alloy wheels (£250)
Clutch cable( 700 miles old)
Engine fan
Air con condenser
Geniune t belt kit and water pump (700 miles old)
T belt covers
Lambda probes
Passenger side door lock
Alarms horn
High and low tone horns
Xenon level sensor
Steering cowl covers
Slip ring
Hazard light switch
Brake light switch
Interior alarm sensor
Interior mirror
Glovebox
Plastic shelf beneath steering wheel
Front wiper motor and linkage
Steering column
4 GTI speakers
Geniune radio
Cd player
Master cylinder and reservoir
Brake servo
Water housing& thermostat
Power steering pump reservoir
Geniune vw clutch kit( 700 miles old)
Engine and gearbox mountings
Flywheel
Convienance ecu
Aibags
P/s window motor
Air con climatronic control panel
Engine ecu (AVY)
dont suppose you have the mats do you ??
cheers
cheers
dont have mate
Power steering pump
Alternator
Exhaust manifold
Ignition coil
Starter motor
Evap canister
Exhaust heat shield
Oil separator
Front calipers
Pads and discs (done only 700 miles) =SOLD
Drivers front hub
Catalytic converter
Bonnet
Boot lock
Drivers door
Subframe
Steering Rack
Anti roll bar
Driveshafts
Door seals
Boot carpets
Engine fan
Air con condenser
T belt covers
Lambda probes
Alarms horn
High and low tone horns= SOLD
Xenon level sensor
Slip ring
Hazard light switch
Brake light switch
Interior mirror
Glovebox
Steering column
4 GTI speakers
Geniune radio
Cd player
Master cylinder and reservoir =SOLD
Brake servo
Flywheel
Convienance ecu
Aibags
P/s window motor
Engine ecu (AVY)
Parcel shelf?
DONT HAVE
Ok, no need to shout :|
[/quote
not shouting mate just didnt realise the caps where on :lol:
Washer bottles ?
bump
Do you have the radiator?
just the air con one
how much for the t belt and pumpp posted? pm please
recieved the discs and pads mate, thanks
