6n2 gti breaking
how much for the t belt and pumpp posted? pm please
bump
  • Replies 152
  • Views 7.4k
bump
bump
Power steering pump
Alternator
Aluminium auxiliary bracket
Exhaust manifold
Ignition coil
Starter motor
Evap canister
Exhaust heat shield
Oil separator
Full cylinder head( cams, rocker cover etc (AVY)
Front calipers
Pads and discs (done only 700 miles) =SOLD
Drivers front hub
Standard shocks and strut tops
Wietec 40mm lowering springs =(SOLD)
Dark grey carpets and underfelt
heater box(heater blower,flaps, heater matrix etc)
Catalytic converter
Bonnet
Boot lock
Drivers door
Subframe
Steering Rack
Anti roll bar
Gearbox Rebuilt by vw 1000 miles ago (£300)
Driveshafts
Door seals
Boot carpets
GTI BBS alloy wheels (£250)
Clutch cable( 700 miles old)
Engine fan
Air con condenser
Geniune t belt kit and water pump (700 miles old)
T belt covers
Lambda probes
Passenger side door lock
Alarms horn
High and low tone horns= SOLD
Xenon level sensor
Steering cowl covers
Slip ring
Hazard light switch
Brake light switch
Interior alarm sensor
Interior mirror
Glovebox
Plastic shelf beneath steering wheel
Front wiper motor and linkage
Steering column
4 GTI speakers
Geniune radio
Cd player
Master cylinder and reservoir =SOLD
Brake servo
Water housing& thermostat
Power steering pump reservoir
Geniune vw clutch kit( 700 miles old)
Engine and gearbox mountings
Flywheel
Convienance ecu
Aibags
P/s window motor
Air con climatronic control panel
Engine ecu (AVY)
If its a 3door, u got the side strips/bump strips?
dnt have
BUMP
bump
Drivers or passenger side door handle with locking barrel? Don't need the actual CL unit, just the barrel for the key and the paddle attached to the back.
dnt have
How much for the shocks?!
PMD
Exhaust? Cat Back
Exhaust? Cat Back
dnt have
what size are the wheeels? pics?
xenon sensor, how much? also do you have any gti badges?
pmd
how much for the anti roll bar?
pmd
drivers side wing mirror complete ????
dnt have
how much for the glove box mate...?
pmxd
hiya mate, bit of a long shot, but i don't suppose you have the black plastic bit that bolts to the front of the engine cover? like a long black strip sort of thing lol. also do you have the part that holds the radiator fan on? the three-legged bit? cheers
sorry dont have
