6n2 gti breaking
PM'ed you! :thumbsup:
  • Replies 152
  • Views 7.4k
Power steering pump
Alternator
Aluminium auxiliary bracket
Exhaust manifold
Ignition coil
Starter motor
Evap canister
Exhaust heat shield
Oil separator
Full cylinder head( cams, rocker cover etc (AVY)
Front calipers
Pads and discs (done only 700 miles) =SOLD
Drivers front hub
Standard shocks and strut tops
Wietec 40mm lowering springs =(SOLD)
Dark grey carpets and underfelt
heater box(heater blower,flaps, heater matrix etc)
Catalytic converter
Bonnet
Boot lock
Drivers door
Subframe
Steering Rack
Anti roll bar= SOLD
Gearbox Rebuilt by vw 1000 miles ago (£300)
Driveshafts
Door seals
Boot carpets
GTI BBS alloy wheels (£250)
Clutch cable( 700 miles old)
Engine fan
Air con condenser
Geniune t belt kit and water pump (700 miles old)
T belt covers
Lambda probes
Passenger side door lock
Alarms horn
High and low tone horns= SOLD
Xenon level sensor
Steering cowl covers
Slip ring
Hazard light switch
Brake light switch
Interior alarm sensor
Interior mirror
Glovebox
Plastic shelf beneath steering wheel
Front wiper motor and linkage
Steering column
4 GTI speakers
Geniune radio
Cd player
Master cylinder and reservoir =SOLD
Brake servo
Water housing& thermostat
Power steering pump reservoir
Geniune vw clutch kit( 700 miles old)
Engine and gearbox mountings
Flywheel
Convienance ecu
Aibags
P/s window motor
Air con climatronic control panel
Engine ecu (AVY)
stub axles?
stub axles?
dont have
BUMP
Hi..
how much for :
Fog light grills
Grill betwin the fog lights
Cup holder
The spoiler (i don't know how else to call it, i'm interested in the part that has the 3'rd brake light on it.. found only on the GTIs :oops: )
Buttons for electric seats, including the jack that the button goes in and the connector that connects to the seat (if you have them)
GTI steering wheel(w/o airbag)
Edited by hhhrobi
Hi..
how much for :
Fog light grills
Cup holder
dny have any of that left mate
do u have both front headlights?
DONT HAVE
rear spoiler?
rear spoiler?
dnt have
Power steering pump
Alternator
Exhaust manifold
Ignition coil
Starter motor
Evap canister
Exhaust heat shield
Oil separator
Front calipers
Drivers front hub
Catalytic converter
Bonnet
Boot lock
Drivers door
Subframe
Steering Rack
Anti roll bar= SOLD
Gearbox Rebuilt by vw 1000 miles ago (£300) = SOLD
Driveshafts
Door seals
Boot carpets
Engine fan
Air con condenser
T belt covers
Lambda probes
Alarms horn
Xenon level sensor
Slip ring
Hazard light switch
Brake light switch
Interior mirror
Glovebox
Steering column
4 GTI speakers
Geniune radio
Cd player
Brake servo
Flywheel
Convienance ecu
Aibags
P/s window motor
Engine ecu (AVY)
Edited by polo gawa
£300 for the gearbox?does it come with everything?and it has no leaks and no whines?would be ideal but it would need to b posted. cheers
sorry gearbox is now sold
Bump
radiator?
radiator?
dont have sorry
i know its not on the list,
Front Windscreeen?
sorry if you dont :)
Front Windscreeen?
NOPE DNT HAVE
Power steering pump
Alternator
Exhaust manifold
Ignition coil
Starter motor
Evap canister
Exhaust heat shield
Oil separator
Front calipers
Drivers front hub
Catalytic converter
Bonnet
Boot lock
Drivers door
Subframe
Steering Rack
Anti roll bar= SOLD
Driveshafts
Door seals
Boot carpets
Engine fan
Air con condenser
T belt covers
Lambda probes
Alarms horn
Xenon level sensor
Slip ring
Hazard light switch
Brake light switch
Interior mirror
Glovebox
Steering column
4 GTI speakers
Geniune radio
Cd player
Brake servo
Flywheel
Convienance ecu
Aibags
P/s window motor
Engine ecu (AVY)
bump
BUMP
Them heater blower flap thingies. How much? Mines got a rattle from a broken...thingy.
CD player? (is it in dash or boot mounted?)
Price?
dont know what you mean mate
