Spraying a bonnet
i have jsut got my bonnet, going gloss black BUT i dont know how much primer and paint to buy???? can anyone advise me on what htey have done befor?? cheers
  • Views 1k
Depends on the part mate.
Get all of the sanding done good and proper, sand it all right down so you get a good finish. Preparation is the key in spraying. Then wipe all your bonnet down with a paint preparation wipe or similar and let it dry off. Then apply 1-2 coats of primer, possibly more.
Then begin applying your gloss coat, allow the layers to set quite a bit before applying the next and then apply your clear.
Try to do it in a dust/dirt free environment and always start the spray off of the panel if using either a gun or a can, and always finish the single spray motion off the panel so you don't get any uneven patches.
Also, don't spray too close to avoid the paint running.
cheers mate, going to do it saturday and will upload some photos, hopefully will be ok :)
yeah like this guy says.. preperation is the key.. dont try and rush it.. especially with the spraying.. or youll get patches where youll need to sand down again and theres always that chance it could always show..
i sanded mine with with the roughest grain of paper and slowly got finer and finer till it was smooth and shiny.. added a cpuple of coats of primer.. again, slowly to get it right forst.. sanded it out just like before and primed it again.. to get it all smooth as i went alon g.. then added the black.. came out really well.. but i then decioded go for a full satin black finish so startted on the whole car now.. lol
my tip = take your time
cheers dudes, just sprayed my GTI splitter and the centre grill Gloss, will the bonnet came and had a dent in the corver so i have to get that sorted >:( will update as progress goes on
