how do you remove a wing on a 6n?
as the title says really is there any spot welds or anything? Thanks in advance.
  • Views 790
No...theres 3/4 bolts underneath the bonnet then about the same inside the wheel arch.
it may be easier to jack the car up and remove the wheel, then the arch liner, then you should have easy access to the bolts.
you may also need to remove the lights, I did when i took mine off but then i was stripping the car anyway
sean
yeah when i had to remove mine.. i had to take the grille away so i could take off the bumper and lower valance to give access to the inside.. i also took off ther wheel and arch liner and then the bolts under the bonnet as sean said and it came away nicely.. out of everything on my car.. the hardest things to take off are the grille.. (without the clips snapping) and the stupid window winders..
body is pretty simple..
