how bad...
will 8j borbet t's scrub on my 6n with NO arch work?
this low...
thanks alot.
jamie
  • Replies 13
  • Views 1.3k
yep!ave got 7.5 all round 16inch!with arch workmy front dnt scrape but rears do!there was only so much i could do with the arch work,were it meets the rear bumper,but my front end is lOw YaLlLl coilovers maxed out to bottom!
:_-)
so 8x14 with no arch work will be a no no?
be fine with the right strech
:D yea should be fine
Will only rub if your really low on the rear. Fronts are fine may rub slightly on full lock.
Go for the higher offset, but yeah should be ok.
fronts will be fine, won't be able to go as low at the back though.
sweet, thanks people. no spacers will be needed then? :)
:_-)
Question to you. Have you had your chassis notched?
the et 15 borbets with 195/45s will not scrub if your down 75-80mm
anymore will
Looks like you've had your arches rolled already so should be fine!
jamie just adjust you coilover to suit you fag..
i had 14x8's et20 195/45 on mine..but had major arch work.
i want LOW though lol
how can i tell if its had arch work already? looks standard but i dont know what it would look liek if it wasnt? lol
Why does it matter if it's had arch gap? Why does it matter how low you are in MM.
Buy the wheels, 8 x 14 et 20/15/25
Put them on the car, then lower it as much as you want and keep going until it starts scrubbing. If your not happy and want to go lower, cut away at your arch lining or get the arches rolled.
