Steering wheel airbag removal 6N2?
Gave up in the end but was trying to remove the 2 springs on the back of wheel so I could get air bag out then wheel off. Any tips on tools to use and which way to moce spring etc?
ALso what size nut to remove steering wheel?
Ta
  • Views 1.6k
Nut is 25mm IIRC.
You need to get a small flat head in as far as possible.
Push the flathead in away from the centre of wheel, only when it is fully in, pull up on it so the head of the driver angles in towards the centre of the wheel.
Nice one, will give that a try.
