Steering boss
I've just bought a steering boss that is meant to fit my mk3 1992 polo. The spline size is correct, but it pulls tight on the taper before it gets far enough on so i can only get a few turns on the thread to tighten it back on and it is too far out to operate the indicator knock off switch. Can anyone suggest a boss that will definately fit (its a 6 bolt pattern for an omp steering wheel)?
  • Views 876
bump.
bump, surely someone has put a 6bolt wheel in a mk3 before?
I've got a momo boss and that fits fine.
cheers bud. can you tell me the specific model or where you got it from. Also did you fit it to the 27mm spline, or remove the taper and fit to the smaller one underneath?
