has anyone ever hit a speed hump with there sump?
i was wondering if anyone has ever wrecked there car going over a speed hump. and if so how low was your car because I'm after some lowering springs but i need to be able to get over speed humps lol. cheers :?
  • Replies 11
  • Views 1.7k
You won't bash the sump on lowering springs... 120mm on coilies you'll start to get issues.
My DP occasionally scrapes and i'm not that low.
My Brothers Merc is on it's 4th sump!!! :lol:
m8 my polos wound down bout 80 mil and i hit a speed bump that had no markings on and was the same colour as this brick paved road once, was doing 30. thought my car was gona fall apart lol but it was fine, wouldnt recomend it tho. i have abit off a problem with bumps but aslong as you go slow and steady you should be fine
I use to catch mine every day on the way to work as there is 2 huge speed bumps on the way. So i bought a lower strut brace and that takes the pounding instead!
yep. catch going over sump splitters build with an island in the middle (to stop you going between them), otherwise sills get it, but really as your sump is almost inline with the wheels normally there isnt an issue, on the mk3 the chassis brace/cat protecting bar takes a beating.
No,but when i was young and stupid i did the 'Bullett San Francisco' run down MK's Avebury boulevard,and when jumping the flat road at the crossing i elevated a MK2 Cavalier like 3-4 feet off the ground - didn't crack the sump but dented it right in deep,it had folds in it. Wishbones were angled up,valance folded back,big spark shower.
It just carried on going..
Steel sumps FTW.
Never in the GT, which is lowered 60/60, but once in the bready, which is standard height.....
Go figure
I've never hit the sump on either of my valvers which have been down 100mil at the front.
Subframe is the first thing to contact the deck, then its the exhaust then its the sump.
So to hit your sump you either have to aim your car at a really retarded angle or kill your subframe and exhaust in the process.
Steel sumps FTW.
I've alwyas wanted to do that....one day....one day :-D
so if i get 60mm on the front it should be fine??
60mm (i took it a fraction lower,to 65 with quarter coil cut) of a PhilJ kit on a MK2 coupe is pretty forgiving. I've got the deeper/lower 6n sump and yet have not scraped it despite not being anal at speed ramps. Wouldn't go lower though,it can start to feel a bit of a compromise when giving it beans on a bumpy B road.
But this is with camber-correction ARB mounts which prevent rub at the back of the arch. Still,the tyrewall will just catch the arch with the sump still three inches from the ground.
If I can get over speedbumps, then I'm sure you can
